Nested family not work in project
Hi everyone, Could you help me this problem?
- I created a nested family include Basins and cabinet , it's i work when i not tick Shared in Basin's family, i can flexible between basin opts. But when i stick shared it's not work.
For example : i switch Basin opt 1 to 3 it work, and 3 to 2 it  work, but 1 to 2 does not work.I would like to know why is it?
please find Revit file attacked below, thank you
http://www.mediafire.com/file/bg19doarzmzdz8v/1111.rvt/file
Are you talking about a message like this...
thank you for reply my topic
- i captured my screen
- when i  click interchangeable basinks from dropdown,it is not showing my basin i need
The problem is with pipe connector within nested families. There are two solutions:
1) Remove connectors from nested families and add in master family. I recommend this, because with connectors within nested families are a lot of issues, e.g. there is no way to connect a pipe manually.
2) Create nested families as not face based.
Thank you so much 🙂
 -i will to try Opt 1.
- To do opt 2 it is hard for me because i am use basins family from manufacturer, do you have idea to create new one from old family of manufacturer, Thanks.
