Unexpected Line Weight Change
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
PhilvK
443 Aufrufe, 2 Antworten
My Object Style line weight setting for ‘columns’ cut in section is ‘4’. My Object Style setting for ‘Walls’ cut in section is 5. When I align a wall, or extend a wall to the column, the line weight of the column changes from 4 to 5 to match the wall. Is that normal behavior?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: PhilvK
Yes, that is normal behavior.   Joined elements share the same line weight and fill pattern.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
You can Switch Join Order...
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Nachricht 3 von 3
PhilvK
als Antwort auf: barthbradley
Great, thank you!
