Negative Wall Base Extension and Cleanups
chughes
chughes
Does anyone else have an issue with corner cleanups when using a negative (-0' 3" for example) wall base extension?  This is consistent across multiple projects.
With negative base extension:
2020-03-11 11_36_45-Autodesk Revit 2019 - [Bono Residence_chughes.rvt - Floor Plan_ Level 2].jpg
With 0" or positive base extension:
2020-03-11 11_36_21-Autodesk Revit 2019 - [Bono Residence_chughes.rvt - Floor Plan_ Level 2].jpg
chughes
Mitered corner cleanup override corrects the problem.  Not sure if this is a feature or not.
chughes
As a followup, this is a known issue that Autodesk is working to resolve.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
