Need help with the roofting!
jgarciacorpus69
jgarciacorpus69
This is how the roofing looks like now, and the wall which won't attach to the roof to make it look like this.
If you don't want the Roof over the Wall, then draw Ref. Plane in Elevation View along the top or bottom of the Roof eave and use Attach Top/Base tool to attach the Wall to the RP.
...actually, I have no idea what you are trying to do.  Can you be a little more descriptive?   Currently,  I see a Gable Wall in front of a Hip Roof.  Are they supposed to interact with each other?   How?
jgarciacorpus69
It is something like this.
And this is how the roofing plan looks like.
That Roof Plan doesn't reflect the roof you have circled in the photograph.  What see from that Roof Plan is two differently pitched Roofs - originating from two different plate heights - intersecting with one another.  But I can't read any of the information in that Roof Plan so it's hard to know for sure.
What is the issue that you are having?  By the way, the roofs in the photo (heritage roof is entirely above the other roofs), and the the roofs in the elevation (heritage roof intersects the other roofs) are not the same.  Which ones is correct?
