Name of the file on the title block
marco.defina
marco.defina
i have my title block of the company. In AutoCad i have the possibility to insert the parameter of the "name of the file", so i can read the name of the file on the Drawings.
It's possible to have on Revit in the family of title block?
Best Regards
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
Kimtaurus
It's possible to do this in Revit.
Place a label on the titleblock with the "File Path" parameter. This will read the filepath + file name.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
marco.defina
Thanks, i have read so much time the entire parameter but i had not seen Smiley Very Happy
