My revit is not working i want help
raysasophia
raysasophia
Community Visitor
Community Visitor
when i close the walls to make a room the walls are invisible only when I put the mouse and over the line that was invisible so it appears but when I give esc it disappears.
In order to troubleshoot this, we're going to need a lot more information.  Is this the first time you are using the software? Does this happen in every view? Every session? etc. etc.
kh_jea
It's a graphic issue, we had the same problem. Try a different scaling factor for your monitor.
