my dynamo interface not showing its base grid and model
Hi everyone,
I'm kindly new to dynamo. I give a little shot to try the interface of Dynamo on my Revit 2017.2, but the thing is the grid on the interface of dynamo is not showing, and when I try to put everything on dynamo, there is nothing shows up. What happen with this?
Thanks for the advance.
Hi, I already check that part, and I already check on the same page like those pictures.
marius.postolachi
Hi pramudiyanto,
I also faced this issue and I solve it by following the steps bellow.
The indications are applicable only if you have NVIDIA Graphic Card
1. Go to C:\Program Files\Dynamo\Dynamo Revit\1.3 (or where the DynamoSandbox ".exe" file is saved)
2. Right click on the DynamoSandbox.exe
3. From the menu dialog, keep the cursor on "Run with graphic processor"  and select from drop-down list "Change default graphic processor"
4. In the NVIDIA Control Panel, under the setting "2. Select the preferred graphics processor for this program", select "Use global setting (Auto-select: Integrated)".
5. In case you have multiple screens, disconnect them.
6. Restart Revit.
Have a great day!
j-tsai
Hi @Anonymous  @ToanDN ,
i have same problem too i followed what you guys said but still not work ,cuz my GPU is not NAVIDIA?
