MULTIPLE ROOMS IN THE SAME ENCLOSED REGION
4 REPLIES 4
RiodanS_NPBM2R39XABZ
910 Views, 4 Replies
Warning: Multiple Rooms are in the same enclosed region. The correct area and perimeter will be assigned to one Room and the others will display "Redundant Room." You should separate the regions, delete the extra Rooms, or move them into different regions.
I was working on a model and shifted some of my walls around and now almost all of my rooms in my project share the same boundary and are redundant.
I've tried deleting the redundant room - When I do this it deletes all 87 room tags.
I have room separators in place - the room boundary is ignoring this.
If I try to place a new room the room boundary will default back to the building parameter and ignore all interior walls.
I've turned on my room references for a visual. See attached image.
4 REPLIES 4
Share the model here.
Hi - it won't let me upload my model. It' too large.
How big?  You can select everything in that floor plan view (rooms, room separation lines, walls, floors, and any other room bounding elements), make a model group, save the group to a new file and share it.
