Multiple Models Coordination
mahmoudhmeid
mahmoudhmeid
Hello Revit Experts
I am facing problem to combine my Revit models (Bridges and tunnels) locating in the same area (New City) (see attached plan view).
Every bridge or tunnel is modeled separately in a Revit project , coordinates are set to be the world northing and Easting with reference to the Survey point ( 0,0 )
Now the progress is to combine all of these models into one master model using (link) option. Is there a procedure to link using ( survey point to survey point) or it is not possible, or do you have any idea to solve this issue, please help.
Note: When I try to link using shared coordinates i receive a message that says ( Models are not sharing same coordinate system.)
Please help
Best Regards
RDAOU
@mahmoudhmeid
In Revit you would establish and use Shared Coordinates ... Read the handout in the below Link it will help you understand how to it works and subsequently how to fix the problem you are facing
https://paulaubin.com/topics/shared-coordinates/
