Lines covered by others lines
Hello everyone,
I have an issue with my lines in my project. I have drawn axes in the family of my bed furniture to show on plans that the axis of symetry of the room is based on the one of the bed.
But, recently, the lines of the axis of my bed turned out continous and not dashed anymore.
I have not seen any clue in my filters / template which forces thoses continous lines.
Do you have any idea ?
03 - what is visible03 - what is visible
(what is visible without the mouse on the bed)
02 - the line I would like to see02 - the line I would like to see
(the bed in the project with the line under I would like to see)
01 - family01 - family
(the family opened)
Thank you for your help,
Yoann
RDAOU
@Anonymous
Most probably the Line Pattern set of the Line Style which you used in the family is not suitable for the scale of this view.
try to change Scale of the View to 1:50 or 1:20 the dashed line should show again
It doesn't seem to be this. Actually, I figured out that even the other styles of lines appear all "continuous" as I draw them. All the lines I draw, even with my "dashed green" type lines appear continuous black.
RDAOU
@Anonymous
Upload the family to have a look on what you have there
Here is the file, but I think it is more the project than the family.
RDAOU
In the project you will need to check it from your end or upload the project instead of family.
You can check the following:
  1. Do you have any view filters applied?
  2. Check any Visibility Graphics overrides
  3. Check the phasing Phasing Filter and Overrides for those too
Thank you very much, it was the last one!
Have a good day!
