Multiple Cameras - Key Plan:
Message 1 of 10
I believe I know the answer, but I hope I am wrong.
Is there a way to select and/or show all camera locations in a plan view?
Hoping to make a key plan as well as view and delete unwanted cameras.
Thanks in advance for any input!  Revit 2019
Replies (9)
Message 2 of 10
You're right; not wrong.  Smiley Wink
Message 3 of 10
L.Maas
What I have done in the past is making use of Dynamo.
I was in a similar situation were I needed a "map" of the camera locations to indicate the location of the different renders. With dynamo I extracted the location of the camera and placed a family on that place pointing in the (approximate) camera direction
Louis
Please mention Revit version, especially when uploading Revit files.
Message 4 of 10
Thanks for the reply @L.Maas!
Sounds great!  Unfortunately, my Dynamo skills are currently poor at best.
Someday though...  However, I will look into this as that would certainly be a good one!
Thanks again!
Message 5 of 10
L.Maas
@Anonymous, I have looked for the script I have used. I needed it quick so it is not the most elegant one.
What it does is:
It looks for perspective views inside the project (the camera views)
Then it finds the origin and direction of that view (i.e. camera)
Then it places a family instance at that point and with that direction
As the family is workplane placed I first have to select a face (a floor in this instance) to host the camera family .
Hopefully a starting point for your dynamo endeavors.
Louis
Message 6 of 10
Thanks for sharing, @L.Maas!
Why didn't you use an Entourage Family?  Maybe have "Alex" standing there looking in the direction the camera is pointed? ...or "Cathy", "Cynthia" or "Florence".  he, he.
Smiley Wink
Message 7 of 10
 Smiley Wink
They can get creepy if you have cameras pointing to certain types of spaces.
Message 8 of 10
What ever happened to "Peeping Tom"? Smiley Wink
Message 9 of 10
@L.Maas, thanks for sharing!
I will surely give it a shot!
Message 10 of 10
Hello, thanks for this.
What package if the view direction node from?
