Multiline Text Parameter Wrap
kporterHBW6T
kporterHBW6T
I love that there is a multiline text parameter available, so that you can hit enter and add a new line of text. (I would love if I could also hit tab, or make text bold, but those are for the ideas forum). But what I can't deal with is that the ONLY way to start a new line is to hit enter - as far as I can tell, there is no way to wrap the text at the end of the field automatically like a normal text box would do. Has anyone found a way to do this that I am missing?
vitorbortoncello
you cand also drag the text box to get multi lines
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
kporterHBW6T
In the process of creating a screenshot to show you that it doesn't work, I discovered what was wrong. If you are typing words, it will wrap. If your word is too long, it doesn't wrap. See image attached. Turns out you were right. 🙂
If only we could use tab, and underline, and such... but that's a topic for a different forum.
