Multi-point Text leader
Is there a multi-point leader you can add to the text leader? Similar to AutoCAD where you can add vertex to a polyline. This would be helpful for finish plans where you want to call out a finish on a group of walls in a room
simple answer.. yes! just click the additional arrows under the leader tab. Hope this helps!
Viveka_CD
Hi @Anonymous
Please see AKN article: Add Leader Lines to a Text Note
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
J3UTB5
Just curious, is the answer to the original question perhaps, "No, there is no way to do this?" I too am interested in doing the same; that is, creating a multipoint leader (not creating a single note with multiple leaders). The original poster's illustration seemed to be a succinct summary of what she is trying to do.
You can add multi leaders to text and tags....keynote and system family tags are still single arrow only. 😞
Still a No.  One elbow is all you get.
J3UTB5
Thanks, ToanDN. I sincerely appreciate your clarity. I must say that I am quite impressed with your ability to distill a whole bunch of verbal hoopla to one concise phrase. "One elbow is all you get." Thank you, again.
