Multi-level Room with Differing Footprints
Message 1 of 10
How do you make a multi level room/space where the room has a different footprint on the second level. For example, a large room where only a portion of it is open to the level above.
Replies (9)
Message 2 of 10
Message 3 of 10
Thank you but that only fixed part of my problem. What should I do in the opposite situation where the upper floor print is larger than the lower. For example, a warehouse with an office occupying part of the main floor and has a mezzanine on top of it. Is there a way to make the Mezzanine part of the same room as the rest of the warehouse?
Message 4 of 10
Same deal.  If the lower footprint is bigger then place the room in the lower level, go to the section and stretch the room's top grip up.  If the upper footprint is bigger then place the room in the upper level, go to the section and stretch the room's bottom grip down.  Results below:
Message 5 of 10
Thank you
Message 6 of 10
ISA_cad03
Hi @ToanDN  I'm hoping you can expand on this a little bit. I am also working on multi-level room, except the room is a little more complicated in section. I have raised the room's top grip up from the basement but it doesn't "flood" into the rest of the room above, see screenshot. I made sure the wall at the first floor opening is not room bounding but nothing changes.
Is there a way to have the room go beyond just the opening footprint?
Message 7 of 10
Jason_S
The Floor in your pictures is also room bounding and that will not allow the room to fill that area marked in the blue on your second image.  Try taking room bounding off the floor in that section.  You may have to make that area with a floor that is only in the area of that room.
Hope that helps.
Message 8 of 10
drenL5229
HI @ToanDN & @Jason_S ,
Saw this post and seemed appropriate for my question as well.
I have a condition where I have a Basement let's say at -10' and then a Lobby on top of it that sits at 0' and adjacent to it I have a Trash Rm which sits at 3' 6". My problem is that the Basement walls are affecting my Room at the Trash Rm since they come all the way to the bottom of the slab at Trash RM. I tried making the Room at Trach RM start higher but I can only do that until I get the error, please see attached a snip below.
Should I create another level for the Trash RM at 3'-6" and use that to assign the Room?
Thanks!
Message 9 of 10
Jason_S
"Should I create another level for the Trash RM at 3'-6" and use that to assign the Room?"
Yes — I would create a dedicated level for the Trash Room, since it sits higher than the Lobby. I wouldn’t necessarily create views associated with that level, but having the level itself will allow you to properly place the Room and ensure all elements within it are associated correctly.
Hope that helps.
Message 10 of 10
drenL5229
Thanks, had that idea but since I have multiple rooms that are at different levels thought better ask first before going down that route.
I appreciate your answer!
