Multi housing workflow
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
what would be the best workflow to manage 60 (6x10) housing project?
Now the Revit project consists of 6 attached houses, each house have multiple groups.
So basically it's 2 groups times 3. v1.rvt [[1][2] [1][2] [1][2]] x 10
Everything was fine and we were able to produce drawings for all 60 houses from this one project, because all 10 houses (on different plots) are the same.
Now there are some differences introduced because of the building errors etc.
Now there are 3 variants of those 10 houses.
(It was 1 variant, copied 10 times v1.rvt [[1][2] [1][2] [1][2]] x 10 )
Now it is something like this:
v1.rvt [[1][2] [1][2] [1][2]] x 3
v2.rvt [[1][2] [1][2] [1][2]] x 5
v3.rvt [[1][2] [1][2] [1][2]] x 2
The changes are small, some doors are narrower, some window higher, but they have to be scheduled.
I see two ways:
A) Use Design options in same v1.rvt
- If more changes are introduced, the Design option management can become nightmare and even now I am not sure how this will work with groups.
B) Duplicate the v1.rvt Revit file two times and introduce the changes for file v2.rvt and file v3.rvt
- Every new drawing and change that is introduced to all houses has to be copied 2 times.
How do you manage these types of projects?
