Mullion Can not Cut Column Twice
qmaA4RKL
Message 1 of 8
qmaA4RKL
Hello guys, I'm currently trying to model curtain wall panels/mullions around columns and it is required to have  them cut the columns as they meet together. However I only been able to do it once (one mullion on one column) and never the second. Any solution to this?
p/s: The family has "cut geometry" checked as well as "void cut when loaded".
Replies (7)
Message 2 of 8
Huh? Going to need some screen captures to understand you.
Message 3 of 8
qmaA4RKL
I would like to cut the mullion to all the columns shown below, however I can only do it once
Message 4 of 8
I don't understand the construction. Wouldn't the Curtain Walls abut the Columns?
..something like this embedded curtain wall?
Message 5 of 8
Are the column vertical mullions or separate elements?
Message 6 of 8
You can also get there by embedding a Basic Wall that is just glazing material and thickness into another Basic Wall Type to which the Columns are Joined.
...Something like this:
Message 7 of 8
qmaA4RKL
They are seperate. I wany to cut family “Rectangular Mullion” to the family “Column” which also has a void embedded within, however only able to do one cut and not multiple, hence you can see a mullion is cut on one side of the column while the others are going through the column
Message 8 of 8
I can't test right now but you can try one of the following:
- Cut Geometry and tick Multiple Cuts
- Place two columns in the same place to cut
- Place a solid mass the same size as the column and Cut geometry: pick mullion then mass
