Moving Elevation Tag
hliS658H
Message 1 of 22
hliS658H
This is probably a very easy question to people who know the answer, but I just couldn't figure out how to move the elevation tag - only the tag - I have no problem to move the view itself by dragging it.
Replies (21)
Message 2 of 22
EATREVITPOOPCAD
post the file - could be a few things... But it sounds like part of your tag is hidden. The default Revit tag is a square surrounded by 4 triangles - 1 on each side (don't need to have all 4...). In that scenario, you would move the square and it would move the triangle. So unhide the rectangle and move it.
The definition of insanity is doing the same thing over and over again and expecting different results
Message 3 of 22
Are you dragging the elbow?
....that doesn't look like a Spot Elevation.  Is it something else? Do you see Constrain and Disjoin on the Options Bar when you select it?  If so, uncheck/check those boxes.
Message 4 of 22
Trying turning off the Crop Boundary temporarily and moving it.  That free it?
Message 5 of 22
mhiserZFHXS
You need to select the box that the marker is attached to. Its invisible in your view. Just hover your mouse behind the arrow, press tab if you need to, and it should pop up.
Message 6 of 22
hliS658H
Message 7 of 22
hliS658H
Turning off crop region didn't help.
Message 8 of 22
mhiserZFHXS
Select the box.
Message 9 of 22
hliS658H
Message 10 of 22
hliS658H
When hover the mouse over the tag, there is no box showing up, it is something different.
Message 11 of 22
mhiserZFHXS
Not over the tag, behind it. Look where the box is located in relation to the tag. You may need to tab through other items to get it to show.
Message 12 of 22
Is it associated to a datum?
Message 13 of 22
Oops. Meant to ping the OP.
@hliS658H : If it's Associated to a Datum, set the Associated Datum to "none".
Message 14 of 22
letsbimtogether
LOL watch it be pinned.
@hliS658H Select the tag and hit U then P on the keyboard.
You also can upload a simplified version of the Revit project here 😉
www.LetsBIMtogether.com
A place that houses various tools (and explorations) I've developed to make a Revit®/AutoCAD® user's life easier (and more interesting).
Here, you'll find a range of plugins, scripts, and applications.
Message 15 of 22
hliS658H
I tried the other choices but not helpful.
Message 16 of 22
hliS658H
I can move the cut plan, just can not move the TAG in triangle shape, or you call it MARKER.
Message 17 of 22
hliS658H
can you move the marker circled in green? If you can, how do you move it?
Message 18 of 22
Just Drag it. Unpin it first if it's pinned.
...by "drag", I mean select it and hold the mouse button down while moving the mouse.  Marker should follow along for the ride.  Yours doesn't?
Message 19 of 22
I'm thinking it's Pinned and you have Select Pinned Elements turned off.
How'd I do?
Message 20 of 22
hliS658H
It is unpinned.  Dragging the blue cut line and scope box doesn't move the marker at all.
