Moving elevation markers in different views / sheets without affecting the elevations
wisedrawing
wisedrawing
I have searched high and low and found some old Revit version answers but nothing seems to help.
I am sure that I am not the only one on the issue of wanting to place the elevation markers in a different position on the site plan and is shown in the floor plans. Obviously per my example they get in the way on the site plan and moving them pushes them off the screen in the floor plan. Moving them anyway also affects the elevation itself. I
I have been resorting to hiding them in the site plan and annotating them, but that seem antiquated
kent.w
Hi Darren 66,
You are correct on two accounts
  1. You can't move an elevation marker in one view and have it remain in the same location in another view
  2. Using annotations is antiquated (and not very BIM like)
To solve this issue use view referencing.  See my screencast below
Kent Watson | AIPAL
www.aipal.com.au
wisedrawing
Brilliant Kent thanks that's great - I was just hiding the old one but the course scale option tidies that up nicely
great screen cast
Cheers
Marli_Swart
Is there a good way to get "Sim" off the tag and to just make it the main tag (i.e. C5, D5 with no Sim after)?
vaibhavparab10
Community Visitor
Community Visitor
just edit it from type properties
fionahung5367
Hi Kent,
I am on Revit 2026.3. I upgraded an existing model from 2024 to 2026.
Where I was able to move the elevation marker independently on one view and not the rest on 2024 model, I can't seem to be able to do that on 2026. Can you confirm if that is a glitch on 2026 and will it be fixed soon?
