Mouse pointer/cursor disappears while drag plan to sheet
- Mute
- Permalink
- Report
I suffer issue of disappearing mouse pointer/cursor while dragging plan to sheet in Revit 2022.1.2
Pointer appears as soon as primary mouse button is up.
I don't see any mouse pointer issues outside the Revit.
I've already tried to workaround the issue with (none had helped):
- Switch to default (None) Pointer scheme;
- Switch ON mouse option "Enable pointer shadow" (I prefer "Windows inverted (extra large)");
- Switch OFF mouse option "Enhance pointer precision";
- Switch ON mouse option "Display pointer trials";
- Switch OFF mouse option "Hide pointer while typing";
- Disconnect mouse (drag with keyboard's trackpoint);
- Switch OFF Revit's "Hardware acceleration" option (in both: "User Inreface" and "Hardware" sections);
- Dock Project Explorer to the right side (I saw somwhere the description of case where pointer was disappearing on left-to-right moves only);
- Disconnect secondary monitor;
Now I wonder ... what else (apart from reinstalling OS or using other PC) could be done to fix the issue described ?
OS: Windows 10 Pro (x64), Version 21H2, Build 19044.1526.
Hardware:
Nettop* Gigabyte BRIX GB-BACE-3160 (RAM:8Gb; SSD:480Gb);
Monitors:
Primary monitor: Philips 275B (2K, HDMI);
Secondary monitor: Samsung T22C350 (FHD, VGA).
HIDs:
Mouse A4Tech WOP35 (wired, USB, double-wheeled);
Keyboard Lenovo SK-8855 (wired, USB, with integrated trackpoint).
*PS:
I'm aware that my 1,6GHz Celeron doesn't suit Revit's system requirements yet I believe this is not the root of the issue as I don't see any critical performance issues (I'd rather count it suitable for software studying). I plan to upgrade If decide to start using Revit as professional.
Please vote for Inventor-Idea Text Search within Option Names
