Modify Room Boundary in Section?
kmfuhrman
Message 1 of 13
kmfuhrman
Using Revit 2015 - the attached JPG shows a stair tower, in theory this is one "room" (Stair ST-1). There is a "jog" at the 2nd floor that continues up through the rest of levels. Is there a way to modify the room boundary to read the "jog" and eliminate the piece of the room that is outside the stair tower (in red)? All walls are set to be room bounding.
Kimberly Fuhrman, LEED AP BD+C
Freelance Architectural Technologist
Replies (12)
Message 2 of 13
cbcarch
The interior walls at each level at the "jog" should be checked to be Room Bounding. Seems like that would do it.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 13
kmfuhrman
They are, as stated in original post. 😉
Message 4 of 13
cbcarch
Well, then perhaps the walls are "leaking" somewhere.
Are any doors offset above the level? What does the Plan look like? Any openings, columns, room separation lines?
Any Design Options? Linked models not set to Room Bounding?
As a quick test, try placing a new interior wall toward the inside of the current walls. Does the room behave correctly?
Cliff B. Collins
Message 5 of 13
kmfuhrman
None of the above. I'm starting to think it has something to do with the vertical partition wall being continuous. If I stretch the room down a level and add a new room, it displays correctly...
Message 6 of 13
cbcarch
Room Computation Height.
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-9D33F884-4BCA-4772-B3E5-1E15A53DEE6E
Cliff B. Collins
Message 7 of 13
kmfuhrman
That worked for the upper floors, but not the lowest (expanded) floor...
Message 8 of 13
gabrielchiew
Hi, is there any update regarding this issue? I am facing the same problem. Because of the room boundary, the roombook quantification is not calculating the wall finishes accurately. Please, if there is any update. Appreciate it
Message 9 of 13
kmfuhrman
I've got to be honest, I posted the original question 5 years ago. I don't remember how I resolved it then. If I did.
Message 10 of 13
gabrielchiew
hi, thank you for your reply. I have resolved the issue. I have to create a level for the room with different area size and use room separator to include the bigger area. Hope this helps.
Message 11 of 13
Steps:
- Make model elements (walls, floor, roof) room bounding
- Set Room Computations to calculate Volume
- Place Room in the level where the Room is largest, in this example it is Level 1
- Go to a section and drag the top grip up passing the roof and the room will fill correctly, jog or not
Message 12 of 13
martijn_pater
Make just the (part) of the floor at the bottom of your red outline room bounding, and the wall...
Message 13 of 13
juliusgerdauskas
Observer
Observer
Woring with 2024 revit and this does not work. Working on stairway and first level has bigger area, others smaller, tried this method, tried additionally adding room separation lines, did not help.
