While working in Option mode it is possible to select objects from Main Model by simply unchecking "Active Only" box at the bottom of the screen.
However, with this box unchecked it is still impossible to use tools from Modify tab. For example I cannot trim or split the boundary lines of a floor in the main model. It requires me to do some extra manual work to finish a simple task. Is there a way to make this tab useable in an Option mode?
