Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
modify bar missing
modify bar missing
Message 1 of 13
modify bar missing
I don't know exactly what said bar is called but it is green and is supposed to show up below the ribbon whenever I select a wall or roof or such to set how long an overhang is or what direction a slope goes but all I see is a thin green line where it is supposed to be. I can't select it or make it bigger and this only happened a few days ago though I've used Revit for at least a year. I think it is called the modify bar since it says that in the name but I'm not quite sure. version is Revit 2017 Educational Version
Replies (12)
Message 2 of 13
Alan.johnson1970
Can you attach a screen shot?
AJ.
Message 3 of 13
Alan.johnson1970
Its hard to understand what exactly that you are missing.
AJ.
Message 4 of 13
Here's a screenshot of a 2019 version of Revit with the bar present when I tried to make a wall. The black arrow is pointing towards it. It isn't present in 2017 version I have on the computer I work on.
Message 5 of 13
Message 6 of 13
Message 7 of 13
All your pictures uploaded are the same....how about a picture of your 2017 version?
Message 8 of 13
I think you are talking about the Options Bar.  Are you saying that the Options Bar is not visible when you draw a Wall or Roof?
Message 9 of 13
If that is what it is called then yes. How do I get it back?
Message 10 of 13
First, verify that it is actually missing.  Create a new roof. It should appear in sketch mode.
Message 11 of 13
nicholas_seibert
Check on the bottom, it can be docked in both places.  The bottom would be just above the status bar - check out this link
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2016/...
If you really can't find it, you could try resetting the UI.  This link has instructions on how to rename the file, and a new one will be recreated on start up. It will reset you Revit UI back to defaults, and hopefully bring back your options bar 🙂
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Hope this helps.
Nicholas Seibert
Principal Revit QA
Message 12 of 13
 the second link did not work like it says :
"we cant seem to find that page" please help i have to finish a whole house by midnight tonight and its already 8😭
Message 13 of 13
nicholas_seibert
