Modify area value in tag room
Message 1 of 13
Hello, there's possibility to change area value in tag room?
Is not uniform with design data.
.rvt attached.
Thank's
Replies (12)
Message 2 of 13
MostafaElashmawy
The room tag calculated the area correctly.
If you want to write a different area, use a text instead of tag.  a tag is used to reflect the real values.
Also you can add  a shared parameter to the tag which you can fill with custom values.
Mostafa Elashmawy
Message 3 of 13
@MostafaElashmawy  so I create a tag without area and than use text, right?
It is not as dimension that I can modify text, right?
Message 4 of 13
MostafaElashmawy
Yes this specific Area parameter is meant to measure only.
Mostafa Elashmawy
Message 5 of 13
@MostafaElashmawy I undrestand the question, than'k.
Only one question: using a text to uniform the size hava to use 1.5 mm of height text, when the label of tag are 2 mm?
With 2 mm to text is bigger compared to the height of the tag.
Thank's
Message 6 of 13
Why do you want to fake the area value?
Message 7 of 13
MostafaElashmawy
it seems that somebody changed the text size without changing its name.
2mm type should have 2mm text size.
& 1.5mm type should have 1.5mm text size.
you should update it.
Mostafa Elashmawy
Message 8 of 13
@ToanDN  don't know if have to put the value on .dwg file.
You see the unevenness of height size text of "label" and "gereral text" describe in message 5?
Message 9 of 13
MostafaElashmawy
Yes I see.
But you need to change it.
The text size should match the text type name.
Mostafa Elashmawy
Message 10 of 13
@MostafaElashmawy
1) Yes I see. ==> The uneveness? Then I'm not wrong about this but program.
2) "The text size should match the text type name." ==> Yes but is for my convenience do that.
I can also do as in the pic that is the same, right?
But most important in this form is to undrestand if is the program that have nonuniformities between text and is not me that I'm wrong, right?
Thank's
Message 11 of 13
MostafaElashmawy
You are wrong.
check below video.
the text size depends on the value you enter in the type properties and not on the name of the type.
a text with text size =2mm will be the same regardless it's in a tag or in a normal text.
a text with text size =1.5mm will be the same regardless it's in a tag or in a normal text.
https://knowledge.autodesk.com/community/screencast/60f45622-e55b-4489-91dc-40a962412482
Mostafa Elashmawy
Message 12 of 13
@MostafaElashmawy  I haden't open type properties of tag and thought the height dimension was 2 mm and though there was noncorrespondence between tag nad text height.
Thank's
Message 13 of 13
MostafaElashmawy
you're welcome.
Mostafa Elashmawy
