modifing more than one filled region
i am working with revit 2017, and i have imported an autocad file.
the colors changed while importing and so i used filled region with the original colors to cover the wrong new ones.
i would like to be able to scale and modify the filled regions together as a unit, is there a way i can do that?
Ilic.Andrej
Import options allow you to preserve the original colors if that's what you want.
Filled region appearance is driven by type properties - so several instances may have the same type. Beside that, you can use the visibility graphic overrides.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
bimscape
Did you set "Layer Colours" to "Preserve" at the time of Import?
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
