Models being represented differently in Project as opposed to family
thayHKKZA
Observer Observer
thayHKKZA
Observer
Observer
Hi, This May be a silly question and a quick fix, but for a while now I've been trying to figure out what's going on with my families in my project.
When I import some families they're represented fine, but more complex families aren't properly displayed in the current project. I've tested it in a new project and they show fine there. I also checked the family and it shows fine in there.
I made sure there aren't any overrides on the graphics, and the visibility settings in the family are all set as they should be, transferred project standard materials from the respective families, and checked family details to see if there were any parameters obscuring the view, and saw nothing that should.
not sure what else to check or do at this point. Section ViewSection ViewNew ProjectNew ProjectCurrent ProjectCurrent ProjectNew projectNew projectCurrent ProjectCurrent Project
Share your current project here.  You can delete everything except the family.
Try different Detail Levels  and Visual Styles.
