Modeling Cross Laminated Timber in Revit
Message 1 of 22
Hello All.  I am trying to create a Cross Laminated Timber wall in Revit.  I would like to create a wall that has boards that are layered orthogonally to each other.  Wondering if anyone has had any success with this?  I am also open to ad-ons but have not found one that is free yet.  Thanks in advance!
Replies (21)
Message 2 of 22
Can't you just layer the laminate build-up in the wall assembly?  Use two different materials/cut patterns?
...something like this?
Message 3 of 22
Thank you. That is what I thought, or have tried anyways. Perhaps that is what I will end up doing but because my graduate research entails modeling the building's energy performance I was hoping to model the CLT wall as closely as possible. As in, demonstrate that the layers are orthogonally aligned and adhered to each other. I have been unsuccessfully trying to get a CLT plug-in to work. I will keep at it. Appreciate your suggestion!
Message 4 of 22
Energy Performance? Is this about the Thermal Properties of the Wall?
Message 5 of 22
RDAOU
@Anonymous
Demonstrate how?!
  1. by having 1x multilayered wall (say with 8 layers in the wall structure)?
  2. or by having 8 thin single layer wall elements joined to each other instead of 1x multilayer wall?
  3. or by having 1x multi-layer wall element consisting of 8 layers converted to PARTS?
the end result in the energy performance would still be the same if your inputs in the element(s) properties tally up and are correct
Message 6 of 22
Ultimately, yes. So I could just set the thickness/materials to match the thermal properties of the wall. I am also providing wall segments hence my focus on the layers. After considering all the suggestions, and successfully downloading a glue laminated timber family, I think I have something that will work. Thx!
Message 7 of 22
Thanks for the ideas! You are right about the end result. I made a wall composed of several thin single layers and was able to create the wall segment figure I wanted. Then I was able to make a thicker single layer wall of a glue laminated timber family I found. I think I am good to go. I so appreciate the help! Thx
Message 8 of 22
I don't understand what you are downloading. Materials?  Thermal Properties?
Use Detailed Elements for Material Thermal Properties | Revit Products 2020 | Autodesk Knowledge Net...
Message 9 of 22
You would need two materials: one is for horizontal wood layer and the other is for vertical wood layer (their properties should be identical except for surface/cut patterns and appearance texture), then assign them to layers in your wall type structure assembly.
And this only for graphic presentation, there would be no difference in thermal value between cross-grain lamination and parallel-grain lamination, if the thermal properties of horizontal material and vertical material are identical.
Message 10 of 22
Thank you! This is exactly what I was aiming for.
Message 11 of 22
That's exactly what I told you to do above.
Message 12 of 22
RDAOU
I hope @barthbradley  doesn't see this 😄
Edit: too late he did
Message 13 of 22
Message 14 of 22
@ToanDN wrote:
It's nothing new.
Yes; it definitely is not new. You are "The Great Repackager".
Whatever.  Glad I could help you -- again.
P.S. I'll probably have another one for you later today, so keep your eyes peeled.
@Anonymous: just to clarify, since this is about Energy Performance; you want to input Thermal Properties for the Wall  Material this way:
Change the Thermal Properties of a Material | Revit Products | Autodesk Knowledge Network
Message 15 of 22
Do you have anything to add to that, @ToanDN?  😉
Message 16 of 22
Sure.  Sometime same or similar responses posted later got credit over the ones posted earlier.  Example: It happens to the thread I referenced above too.
The difference is some people choose to move on when a few choose to be salty.  In the end of the day, OPs get the answers and that is what matters.
Message 17 of 22
No, I mean do you have anything to add about Thermal Properties for Energy Analysis?
 About Thermal Properties for Energy Analysis | Revit Products 2016 | Autodesk Knowledge Network
Message 18 of 22
RDAOU
That view range post lol... you're gonna keep on rubbing it eh? I seriously didn't notice your reply till you pointed that out here...twice lol
I sort newest first and rarely do I scroll to read other replies...but you r welcome to repackage any of my replies lol eye for an eye
Message 19 of 22
View Range? What are we talking about?  I'm lost.
Message 20 of 22
RDAOU
Just another post where it seems toan had a similar reply which got lost in a long back and forth conversation and I took the credit for the solution lol
