Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Model upgrade Revit 2009 to 2018 and failed to open document error
Message 1 of 38
I have Revit 2018 educational version.  We have utilized the program for a couple of months now, saving the same project under the same name.  All of a sudden it wont open the project saying it was created in an older version and needs to be upgraded.  However, it was always created in the same 2018 version and only used in that version.  Even if you say to upgrade it, it says it failed to open document.  Below is what appears. upgrade.PNGupgrade.PNG
Title edit: Model upgrade Revit 2009 to 2018 and failed to open document error
Replies (37)
Message 2 of 38
Update your Revit 2018 to the latest build 2018.2 or whatever it is.
Message 3 of 38
Will try.
I used the backup file and it worked fine without having to upgrade. I was
able to continue to work off the document without the upgrade. This
happened with other students projects have been working on as well.
If anyone else has any thoughts, please let me know.
Message 4 of 38
RobDraw
I've been seeing similar messages when running an audit. Probably not related, but watching for responses.
Rob
Message 5 of 38
Viveka_CD
Hi @Anonymous
Please check the Desktop App to see if there are any Revit updates available. For information on using the Desktop App see the following article: About the Autodesk Desktop App
Note: If you are not able to download updates through the Desktop App, the following article has information on downloading updates through the Autodesk Accounts page:
Install Updates, Add-ons, and Enhancements
Message 6 of 38
I updated Revit to Revit 18.2 and I am still having the issue.
It states to upgrade the model from 2009 to 2018 (even thought project was
made in Revit 2018) and I select to upgrade the model. It then opens Revit
and states failed to open document.
Message 7 of 38
Viveka_CD
Hi @Anonymous
Thanks for getting back.
Can you send us your template file and recent journal file to investigate this behavior?
Also, please send a screenshot of the error message.
I can send you a private folder to upload if you chose not to share publicly. Let me know.
Looking forward to your reply.
Message 8 of 38
RobDraw
Does the model open, or is it some other "document" that is failing to open?
Rob
Message 9 of 38
Viveka_CD
Hi @RobDraw
Once we hear back from the OP, his journal has to be parsed for a load exception error and usually, the underlying cause is a hard disk space jam.
If the file is corrupt and has to be recovered, we can do so only from a backup file.
Message 10 of 38
---------- Forwarded message ----------
Date: Fri, Feb 16, 2018 at 10:49 AM
Subject: Re: Upgrade model
To: autodesk.prod|50510ebc|
[email protected]
Attached is the file itself and the template
Message 11 of 38
Matt__W
@Anonymous there's nothing attached.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 12 of 38
MostafaElashmawy
I think the problem is with a family you loaded from internet to the project.
may be that family was created in 2009 version.
think about the families you recently added to the model.
Mostafa Elashmawy
Message 13 of 38
Viveka_CD
Hi @Anonymous
Can you resend the file?
Message 14 of 38
Hi Viveka,
I'm having exactly the same issue. All of my backup files generate the same error and my program is up to date. Is there a way to retrieve my work?
Message 15 of 38
Matt__W
@Anonymous can you upload a copy of the latest file?
Also, please review this AKN article for information regarding where to find any available product updates as well as information about how to install them. Just want to make sure you have the latest updates installed.
INSTALL UPDATES, ADD-ONS, AND ENHANCEMENTS
https://knowledge.autodesk.com/customer-service/download-install/install-software/update-software/en...
Matt Wunch
Twitter | LinkedIn
Message 16 of 38
Hi Matt,
I've just updated to 2018.3, but am still having the same issues. I appreciate you having a look into this for me!
Message 17 of 38
Hello, @Viveka_CD,
Did you ever find a solution for this issue? I am having the same problem.
Message 18 of 38
I am having the same issue. I have a file that was made with revit 2018 and it says it has to update from 2009 to 2018 and then says failed to open document.
Message 19 of 38
Viveka_CD
@Anonymous, @Anonymous, @Anonymous
Please upload your journals, Revit files and other files we need for diagnosis using the collector extractor folder - see link below. Let me know if you have any questions.
Revit - Collecting and sending diagnostic data to Autodesk Technical Support
I can share a private folder if you'd prefer for each of you.
Looking forward to hearing from you!
Message 20 of 38
cholden
We have also had this issue but ONLY with projects we are pulling down from BIM 360. We are on 2018.3.1. It's happening on multiple projects. Any solutions?
