- Mute
- Permalink
- Report
Hello, please see screen shots:
the print to PDF does not match the Revit view, and the model is rendered in wire frame, see thru.
I did print this same sheet correctly before, however the setup was different. Before I had one plan view, with model and raster image, and it would print as per Revit View (see left).
The new sheet setup are actually two plans overlapping: one with the raster image and the orange blocks, and one plan with the white roads (hidden lines). I needed this because the roads need to be hidden lines, and stay white, while the generic model for the orange building would not print colored unless in shaded view.
Hence, two overlapping plan views were arranged, one hidden line and one shaded.
But they do not print correctly. Anyone with the same issue?
This is Revit 2018.3.1.2
thank you
regards
gio
