Model monolith ramp and curb with hosted railing
cbt990
Message 1 of 25
cbt990
I am revising the design of a ramp on my site to reflect the actual formed monolithic structure:
To model this, I swept the cross section along the ramp profile with no issues.
But now I can't host my railing to the monolithic ramp, whether modelled as a Site or Floor category.
Currently it is hosted to a wall which is hidden from view:
So how can I model the monolithic ramp and maintain the ability to host my railing to it
Thank you.
Revit is amazing
Replies (24)
Message 2 of 25
Why don't you just to it as a sweep?
Message 3 of 25
cbt990
I made it as both a Site sweep and a Floor sweep. Can't host the railing onto either. Should I be able to?
Revit is amazing
Message 4 of 25
In-Place Family? No, if you mean you just Categorized the Family as Site or Floor.
Message 5 of 25
cbt990
So what is the right way to create the element such that rail hosting ability is enabled?
Revit is amazing
Message 6 of 25
Why does the Ramp need to be monolithic?  You can always Join Geometry to make it appear monolithic.
Sloped Floor w/ Slab Edge and hosting Railing:
... or more like this:
Message 7 of 25
cbt990
Right. In that case, the ramp should be a floor with modified sub elements, and the thickened edge should be a modeled in place floor so that joining works?
Revit is amazing
Message 8 of 25
What I showed above was achieved using the floor slope arrow tool, but sure you could do the same with Modify Sub Elements.
...the main point I'm making is that Join Geometry is all you need to make something look monolithic.
Message 9 of 25
cbt990
How do you preserve orthogonal ends of the sweep?
Revit is amazing
Message 10 of 25
If you create the curb using a concrete beam then you can chamfer it with a ref plane or an opening by face.
If you create the curb using a model in  place sweep then add a void in the same model in place to cut it, or add a  small horizontal segment at the end, or use a blend instead of a sweep.
If you model the curb using a slab edge then the end is always plumb.
Message 11 of 25
cbt990
Great, learned about the Slab Edge tool. Thank you!
Revit is amazing
Message 12 of 25
Why don't you use Slab Edges or model it as another Floor? As long as the elements are touching and share the same material, they will join together to look monolithic.
Message 13 of 25
cbt990
Revit doesn't allow me to select a floor as a target for a slab edge, only a slab.
Revit is amazing
Message 14 of 25
Sequence:  Create a flat floor, add slab edges, then add slopes to the floor.
Message 15 of 25
cbt990
The slab edge doesn't follow the edge once the floor sub elements are modified:
Revit is amazing
Message 16 of 25
cbt990
I was able to get it to work with the following sequence:
Create flat floor
Split floor into ramp segments
pick individual lengths of edges for the slab edge, rather than the whole length of the ramp.
Then ramp can be modified!
Revit is amazing
Message 17 of 25
Create flat floor
Isn't you sequence the same as the one I posted?  The idea is you need to add slab edge where there is no slope at the floor.
Message 18 of 25
cbt990
The monolithic join isn't working for me:
I looked a little closer and noticed that the boundaries of the thickened edge and ramp are not perfectly coincident along the entire length of the ramp:
The gap measures to 1/256".
I can't get it to work in either order:
Any suggestions to troubleshoot? I already tried bumping up the lip 1/256" and it changed the actual dimension value to 0-0 but it still won't join.
Thank you
Revit is amazing
Message 19 of 25
Is the misalignment on purpose? If the targets aren't aligned, then use the Linework Tool to clean up.
...wait a minute! Something doesn't compute here. Post the File.
Message 20 of 25
cbt990
Could it be owing to the fact that I have a variable thickness ramp with modified sub elements?
Revit is amazing
