Model in Place
Model in Place
Message 1 of 9
Model in Place
Hi guys,
I am struggling with modelling in place. I have modelled a panel (wall) using extrusion and now it won't seem to let me move it freely. Can anyone help at all?
Pippa
Replies (8)
Message 2 of 9
Lance.Coffey
Autodesk Support
Autodesk Support
Thank you for the question @Anonymous !
If you create a new in-place wall, with a simple rectangular extrusion, are you able to move that wall?
            I tested this on my system, and found that the wall should be able to move parallel to the level/workplane in which the wall was created, but would not move up/down (as it is hosted to the level/workplane).
Lance Coffey
Technical Support Specialist
Message 3 of 9
Hi Lance,
Thank you for your response!
I have modelled a quick in-place wall with the plane set as the floor, extruding either upwards and side-to-side and it allows me to move it freely completely. Maybe my other wall isn't working because I set the plane as a vertical plane (in elevation rather than plan)?
Pippa
Message 4 of 9
Lance.Coffey
Autodesk Support
Autodesk Support
Thank you for the update Pippa!
To check if the issue is with the current face/workplane, try editing the family and Pick a New Workplane.
Lance Coffey
Message 5 of 9
Why don't you convert it to a Loadable Family?  Be easier to place multiple instance.
Message 6 of 9
martijn_pater
You can edit the model-in-place family, create group in the edit environment and save that as loadable .rfa
Or do it from scratch as loadable family ( new -> family template, generic ie.)..
edit: like @barthbradley mentions above actually
Message 7 of 9
Hi Lance,
I managed to fix it. As I had built my model as an in-place wall, it had certain parameters which reduced it flexibility. I copied my extrusion over to a new in-place GENERIC model and that has allowed me to move it freely.
Thank you!
Message 8 of 9
I have now done it in a family so I can do exactly as you mention.
Thank you!
Message 9 of 9
Thank you 😊
