Model Geometry Projection Lines showing as Cut Line lineweight
sjb_00
sjb_00
I am using Revit 2016 and am having an issue with model geometry showing up in orthographic views as all one heavy lineweight.  The projection lines appear to be showing as the same line weight as cut lines.  However, changing the projection line overrides has no effect on the projection lines.  Changing the cut line work override lineweight does change lines cut in view, but has no effect on the projection lines.  Does any one know why or how to fix this?  If it was just one family I could see it being something wrong with the family, but I notice it in all geometry (casework, walls, generic, etc.).
chrisplyler
Ideas:
1. If your geometry is being displayed as an underlay or a state similar to underlay - and this could be the case for a few different reasons such as; it's actually set as an underlay, you're in a view discipline such as one of the MEP ones that turns all non-MEP elements into an underlay, it's being treated as an underlay because of your phase and phase filter settings, etc. - then the line weight/color/pattern settings will be overridden by the halftone/underlay settings.
2. Depending on the linewidth settings by scale, sometimes the difference between 6 and 8 is pretty noticable but the difference between 1 and 3 is not.
sjb_00
Thanks for the response. I actually figured it out. It was an issue with the view template assigned to the view. It was using a view template for a plan view not an elevation view. Switched view templates and it resolved the issue.
[Description: http://www.baylissarchitects.com/BALogoEmail.jpg]
Sloan Bauer
sbauer@baylissarchitects.com
bayliss architects,p.c.
p:406.586.5007 f:406.585.8337
Find us on: Facebook, LinkedIn, Instagram, houzz
________________________________
Copyright (c) 2014 Bayliss Architects, P.C. All rights reserved. Reproduction of this email/attachments and/or substantial re-use of these electronic documents without the express written consent of Bayliss Architects, P.C. violates the copyright laws of the United States and will be subject to legal prosecution. This email, including any attachments, is confidential and may not be redistributed without permission. If you are not an intended recipient, you have received this message in error; please notify us immediately by replying to this message, and then delete it from your computer. Thank you.
