- Mute
- Permalink
- Report
For a lighting project the existing ceilings consist of 2x2 and 4x4 grids. They have linear 4" wide fixtures installed. But instead of cutting off 4" from one tile, they created a 4" gap for the linear fixture and filled that with the fixture (and a blank to fill the gap to the wall). See picture below. So, each tile on both sides of the fixture still is a full tile.
with regular ceiling tool there isn't an option to add those 4" strips. My other options are to create separate ceilings or to sue something like a curtain wall....
on a previous project they had one half-tile offset in a room and I just used 2 ceilings. Here a long hallway and many rooms have multiple of these " gaps".
Is there an easier or simpler way to model that? Or is multiple ceilings what I have to do?
Edit: I created walls that are as wide as the gap (actually 3.75" based on submittals). I placed them where the fixtures are and to have the base for the wall be the same height as the ceiling. The distance is 8' between them (8' 3 3/4" o.c.)Then I auto-placed 4x4 ceilings in between the " walls". Then I placed the fixtures on the walls. At least now the ceiling looks like in real life. I'm just not sure this is the best way...
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
