model displaying in wireframe
Hello I have been using Revit 2019 for few years now, just upgraded to Revit LT 22. I have upgraded my template which works fine apart from when i put in realistic mode my model instead displays as wireframe?  is this a material issue?
sefanja-verkaik
If it is a corrupted 3D view, creating a new 3D view and attaching the same view templates should solve it.
(Suggestion from barthbradley)
Hi guys so i have done the update buts its still not working. Its not just 3D views its also elevations views example below. It displays fine in all the view modes apart from realistic I've tried multiple models some upgraded from 2019 some created from scratch in 2022. I have checked the materials still have the photo texture with it and they do.  Out of ideas
any ideas????
RDAOU
@Anonymous
Try the either of following
  1. Toggle between perspective and ortho
  2. Adjust the Eye Elevation and Target Elevation
  3. Disable use of Hardware acceleration...if this fixes it, then you must look into the compatibility of the GPU and/or check if drivers need update
Unload/switch off any unnecessary CAD links
it was hardware acceleration.. thanks
