We have a coworker who is working in a Revit model and late yesterday morning the file seems to either have corrupted itself or something else.
We have tried turning off hardware acceleration and tweaking some graphics settings, but the model is still the same and it is making it hard for him to work. I am just looking into some inside knowledge on what might be happening. I have included a picture of the model below.
Solved by ToanDN. Go to Solution.
is it just the one View?
Looks like edges are turned off. Is "Show Edges" unchecked?
Edges have been turned on and this is the result.
The edges are not showing, but the model details are still bleeding into on another.
Is this normal, or is there a way to fix this?
Thank you
Is the Transparency intended?
Remove the Transparency and it'll probably be right as rain.
...Do you have elements in the Project that are placed far, far away from the Internal Origin?
...Are you Phasing Construction? Set Phase Filter in "Show Complete".
...Have you been washing your hands?
