Mitering the End of a Railing to turn down towards the floor.
AUnalDSBDB
Observer Observer
AUnalDSBDB
Observer
Observer
I'm working on this railing and I want to miter the corner where the last baluster and the rail structure meet. Not sure what I'm doing wrong. The type is set to miter. I've attached images for more context.
Screenshot 2025-10-01 160157.pngScreenshot 2025-10-01 160224.pngScreenshot 2025-10-01 160241.png
Mike.FORM
You have not set a position for your handrail.
However, It would be better to use the top rail element with the same properties and turn off your start and end posts for your balusters as well as the rail in your rail structure.
AUnalDSBDB
Observer
Observer
It worked! I think whoever modeled it previously had the rail structure acting as the top rail but I turned that off and the start and end posts and then turned on the handrail then edited it's type so the extension went to the floor and it worked! Images attached!
