Missing Survey Point in Revit 2020.2
Revit 2020.2
Units are Meter, Rounding 3 Decimals.
Floor Plans: Site.
I unclip the Surveying Point and move it to Northing 200000, Easting 600000, Z 300 (Swiss Coordinates).
I clip the Surveying Point again. The Surveying Point disappears in Site floor plan.
This did not happen before. I used Revit 2020.0 and it worked fine.
Important aspect in order to combine my Civil 3 and Revit projects.
Are you saying that the SP is/was visible in the view when it is unclipped?  If so; that's weird.  If not; I suspect the new coordinates place the SP outside of the View Range.
Other troubleshooting steps:
-Turn on Reveal Hidden Elements.
-Turn off View Crop.
-Zoom to Fit
Yes, it was visible.
When you clip it, it disappears.
I tried all your suggestions.
None works.
I did this workflow moving the SP, etc. before 100 times.
State plane coordinates, Civil 3D - Revit collaboration … .
Since Revit 2020.2 I have the problem.
What are View Range settings?
Yes, I have to move up the elevation of the Cut Plane in View Range. Then everything works fine and the Surveying Point and the Project Point are visible.
Thanks!!!
