Missing surface imported file into revit
yasinbal
yasinbal
Hi everyone,
I have been working on a furniture file to import into Revit. The product is dwg-igs file and I am trying to import it into Revit. İt works well import into 3ds max and shows up well in Fusion 360 either. Unfortunately, there are some missing surfaces for Revit.
I am sharing some screenshots with you. Waiting for your help.
Best wishes.
bimscape
Do you have the screenshots?
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
yasinbal
I have added some now. Sorry, I thought I added but apparently I couldn't.
bimscape
Is there an option to turn on 2-sided faces when you export?
Kind regards,
Ian
lucdoucet_msdl
@yasinbal
You can use FormIt as a intermediate step between your DWG and RFA formats.
If you have the FormIt Pro subscription, import the DWG directly into a new AXM file and assign the geometry to a furniture type, then import that into a furniture template RFA.
If you don't have the FormIt Pro subscription, you can export the DWG to either a SAT or OBJ (depending on whether you havec materials) using the free web version of FormIt and complet the above steps into Revit.
-luc
