Is there a way where we can add keynotes to mutiple objects at the same time like "tag all".
Our projects require adding keynotes to many elements. So far, we have been individually selecting the object to add key note.
If you have any solution to this ,please share.
Thanks in advance.
What kind of keynotes are you talking about? Element keynotes or any other? If it is element keynotes it is probably easy to select all elements and add a keynote tag to them, with a Dynamo script.
I read that you cannot tag keynotes with dynamo due to limitation imposed by Revit's API. Is there a way to do this?
Thanks.
