Missing Library name "Roombook Library"
I am trying to use the extension Roombook Areabook Buildingbook 2016 to calculate the room quantities of a project but I'm geeting an error dialog saying : "Missing Library name "Roombook Library" Please add library name from Options/File Locations / Places. I've already checked the article below but I still have the problem, even though the instalation of the extension is folowing the steps required and the folders are correctly located.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
had this problem too,
If this error occurs, check the library locations.
C:Programdata/autodesk/RVT2018/libraries/choose one of those maps and the area/room/building book libraries should have a seperate map, each.
if that's the case.
Go to Revit > Options > files locations > places
Here you can add those seperate library maps.
BUT you have to make sure the Library name (in front of each locations) has the name of each library.
for example Roombook Library > locationpath: C:programdata/autodesk/RVT2018/library/germany (or something else)/Roombook library...
hope this helps
