Missing Architectural Default Template
11075333
New Member New Member
11075333
New Member
New Member
I am missing the architectural default template.
  • I have tried downloading the US English Residential Content Pack v1 for Revit 2026, which I'm not sure if it contains or not, but it is the closest thing I could find.
  • I've checked in my C drive under English Imperial, and it just doesn't seem to be there, but I believe it is the only template with the Exterior Wall Exterior - Split Face and CMU on MTL. Stud wall type for a school project.
  • I read on another forum that the Default.rte is the same as the Architectural default template. If it is, then I really only need help with finding this wall type.
Does anybody know how I can get access to this template?
mhiserZFHXS
There is no Architectural default template anymore. Its just metric and imperial.
New Member
New Member
Do you know where I can locate that wall type otherwise?
mhiserZFHXS
It looks like that is still in the Imperial template.
New Member
New Member
I wasn't able to find it in the regular default template, but I did find it in the Imperial multi-discipline template. Thanks for your help!
