Misbehaving Radial Array
9 REPLIES 9
Message 1 of 10
jprash78
618 Views, 9 Replies
Hi, I'm really fighting this one.  The radial array radius parameter is knocking the deck trusses out of whack, i.e. not aligned to left/right and front/back reference planes.  The out-of-whackness becomes more apparent as the deck truss radius offset parameter is increased.  How do I get them aligned?  Thank you.
Tags (1)
Labels (1)
9 REPLIES 9
Message 2 of 10
_Vijay
in reply to: jprash78
how do you need exactly? any sketch
Message 3 of 10
jprash78
in reply to: _Vijay
I am envisioning the components at 0°, 90°, 180°, and 270° will be aligned with front/back and left/right axis.  I wonder if the solid elements in the embedded Family are not constrained enough.
Message 4 of 10
jprash78
So it appears when the array is initially created/placed in hostfamily/project, respectively, the elements at 0°, 90°, 180°, & 270° are aligned.  Then misalignment begins when the radial array is flexed.
Update (5-min later): it appears the embedded Family of the deck truss needs to have some "balance" about the left/right ref plane.  If I draw an invisible symbolic line to align with the far right edge of the modelled solids, then mirror about the left/right ref plane, it will align like I am hoping.
Message 5 of 10
jprash78
It appears there is some centroidal assumption Revit applies when radial arraying, in this case the arrayed element center is slightly to the right of the left/right ref plane.  I'll be...
Message 6 of 10
I don't understand the issue. Can't you Rotate and Lock the Array?
Message 7 of 10
in reply to: barthbradley
Message 8 of 10
Message 9 of 10
jprash78
Okay apparently I didn't do enough SnagIts to make my point smh
Where is the radial array creation process do you lock the element may I ask?
Message 10 of 10
Not sure I understand you. But I just selected all the Model Groups making up your 6 element Array and Rotated it so that one of the Elements were Aligned precisely to the "Center" Ref. Plane.  Bada Bing.
...and I flexed it afterwards by changing the "# Deck Trusses" parameter value (e.g. 6 to 12 to 24 -- so on and so forth).
