Mirroring or flipping the model using a formula
Hello There,
I have created a window family. And I have two types in the family. I want to flip (exactly mirrored model)  the frame in one type.
I know that, we can create the model and mirror it and make the mirrored one invisible in one type. But is there a way to achieve this with the help of a parametric formula?
Please let me know. Thanks in advance.
Wouldn't rotating it in one view, MIRROR it in another? You can make the rotation a angle parameter.
Can you use the flippy things?  Or do you only want to mirror a part of the family?
....but you can't parameterize the toggles, @ToanDN
@barthbradley  I see.
@Anonymous  Is having Visibility parameters for non-mirrored and mirrored frames not parametric enough for you?
@ToanDN Thanks for the reply. This is only a part of the window family. I need to mirror this part using a parameter
