Mirror Project Tips & Tricks - Mirror Linked Revit Models
chandler
chandler
When I use the command Mirror Project on a project with other linked models.  Will it also affect their base files? If not,  how do I also mirror them at the same time?
AbdulKareem_Elsabeeh
Mirror building means diffrent set of drawings, so you need to mirror all files and relink them to get the new mirrored building.
RDAOU
@chandler
No it doesn't...Mirroring the link does not affect the original model of that link. It only mirrors its image in the main model.
  • Either you could open the originals and mirror those
  • Or if you want to keep the originals you can
    1. link them/each into a blank model >>>
    2. Mirror the link >>
    3. Bind the link
    4. and save as a new model mirrored and reuse those in lieu of the originals
What you need to keep in mind is that mirroring the project at a late stage of the design may cause various errors (some of which may not be ignored). Hence, Link/Bind might be your only way around such cases
Mirroring of Revit project process should be executed on all disciplines files at scheduled millstone before submission, to extract a correct set of drawing mirrored as needed, this process shall be occur with each submission; thus open the originals and mirror them. I don't agree with the option of keep the originals without mirroring, that will be confusing, where the links will not be placed/federated correctly when they come to Navisworks.
Our process is mainly focused on mirroring the projects and minimize the efforts required by MEP discipline of re-hosting their elements.
RDAOU
@AbdulKareem_Elsabeeh
Your process is not the topic of discussion on this post; hence, you should not feel compelled to agree or disagree to anything!!!
You can get both a correct set of drawings and the properly set-out federated model in Naviswork using mirrored Links. If you are unable to do that at your end then it would be a good reason for you to start a new post because asking your team or consultants to model everything twice on projects with mirrored units would be quite a waste of time and money for Dar Al Handasah
