is there any solution to apply circular texture in Revit family?
Let's say I have a circular texture and I want to create a material like the one below.
As far as I know it's not possible natively, so any ideas how to get it in Revit e.g. by using other software?
Test samples in attachment
Is this hypothetical question? Or you have the family/component and the Images you need to use as material?
If you do post it
Well the image you added is not a pattern it is more of a linear gradient. The one on the porcelain pot is more of a pattern ...as long as you can keep the sketch lines continuous the better it maps
Sorry I have deleted it!! It was the same family you have posted. You just need to amend the profile you used (its consists of multiple segments)
@RDAOU thanks for the explanation, continuous line sketch does the work (once you have a pattern Image):
What I wanted to achieve though was something slightly different, a linear gradient you would call it, where we have only 1 round texture available, like this one (also attached):
As I deduct the only way to solve this issue would be to redo attached texture into the squared pattern in any graphic program and then apply it in the model. I will test it out later on.
