Microsoft Surface Book Revit 2014, 2015 & 2016 problems
VJGnewman71
Message 1 of 57
VJGnewman71
Is anyone using the new Microsoft Surface Book with I7 processor and 16 GB RAM? I was able to install three versions of Revit (2014, 2015 & 2016).
The problem is that all versions of Revit flicker and hangup while trying to use it. It seems like a graphics driver issue with just Revit.
AutoCAD 2016 works fine.
Replies (56)
Message 41 of 57
Tengo una laptop toshiba con 12 gb en memoria tarjeta nvidia de 2 gb procesador i7 y 1 tb en disco duro..he estado intentando insyalar revit y cada vez que lo instalo me marca error pues unas ventanillas no dejan de parpadear en la parte inferior derecha y ademas no se cargan de entrada todas las herramientas... tengo windows 8.1 ya intente con version 2015 y 2016 y no sirve. Que hago????
Message 42 of 57
@HeinBond_Jeff wrote:
Revit 2016 seems to be working fine for me. I turned the screen resolution down to 1680x1050, and set the scaling to 100%.
This fixed worked for me.  I had to do both, but I am getting away with the 150% scaling without crashing.  I hope there is an actual full fix in the future.  I thought the surface book specs were made for CAD.
Specs: Surface book i7 8g 256
Message 43 of 57
I concur. Once the display scaling is set to 150% the issue seemed to resolve. My Surface doesn't have a 'log off' (meaning I haven't found it yet) so I just shut it down & restarted. My eyes don't care for the smaller text & button sizes but that's ok (showing my age ) 🙂
Message 44 of 57
awesome awesome awesome!
Message 45 of 57
CraigTaylor4588
Observer
Observer
Looks lik ethe latest update to the video driver now allows you to run revit in the full resolution of the Surface Book with 200% scaling.  No joy if you you are using multiple monitors that dont have a high enough resolution.  You will have dumb down the resolution to suit those monitors.
Message 46 of 57
The 4-20 mega update did not fix my issues.  I still have to run reduced relsoution and scaling.
Message 47 of 57
KARLLUNDIN4864
The latest updates + the intel driver updates did the trick and fixed the flicker on my surface so now I can use it at a higher scaling. Getting better!
Message 48 of 57
patrick_flores
Awesome...I might go by another one..I loved my surface pro 4, but as much money as I paid I wasn't willing to be a beta tester for Microsoft and Autodesk.
Message 49 of 57
I'm sure you know by now but the logoff is located under start, at the top where your username is, and then signoff
Message 50 of 57
Vitornis
The solution setting the scaling to 150% worked for me also.
Message 51 of 57
Hi I've just installed revit 2017 and it works much better, no scaling necessary or messing with resolution.
I do have a problem with the  Nvidia GPU, since I can't turn on hardware acceleration with the Nvidia chip. I tried disabling this GPU it and found out that Autodesk lets me use hardware acceleration with Intel HD520 GPU and it works faster than Nvidias "+-GT940M" in software emulation mode.
Dynamo also shows 3D preview.
So now I disable Nvidia's GPU before opening Autocad 2016 or Revit2017 to get better performance.
Anyone has had a similar experience?
thx,
Errol
Structural Engineer.
Message 52 of 57
pan.davarias
Hello. I cannot find out any information on the graphics card for the Surface Book.
We all know it is new card built by Nvidea but thats about it..
Any ideas?
I am running the Surfacebook 16gig, i7m 512mg
Message 53 of 57
I just got the I7 16 meg a few days ago. Loaded revit 2017 today and played around a bit with it but didn't do any serious work yet. So far... everything works fine.
Upgraded from the first surface pro. Seems fine and a few test renderings were absolutely quicker.
Bob
Message 54 of 57
I also was a bit impatient and did not read the fine print. Thanks to all who helped post about this topic. The change to 150 percent fixed everything right up!
Message 55 of 57
I bought a Surface Book this past month. It has a new integrated graphics processor that appears to be incompatible with REVIT 2016.
Revit will not open fully.I have tried adjusting the scaling and the resolution, but no success.
Attached are my System Specifications. Does anyone know if there is a fix.
OS Name Microsoft Windows 10 Pro
Version 10.0.14393 Build 14393
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Manufacturer Microsoft Corporation
System Model Surface Book
System Type x64-based PC
System SKU Surface_Book
Processor Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz, 2808 Mhz, 2 Core(s), 4 Logical Processor(s)
BIOS Version/Date Microsoft Corporation 90.1427.768, 12/19/2016
SMBIOS Version 3.0
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Microsoft Corporation
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Slate
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\windows
System Directory C:\windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.14393.206"
Time Zone Central Daylight Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.9 GB
Available Physical Memory 11.5 GB
Total Virtual Memory 18.3 GB
Available Virtual Memory 13.6 GB
Page File Space 2.38 GB
Page File C:\pagefile.sys
Message 56 of 57
The Surface PRO will work with Revit but the Surface BOOK is the problem.
D
Message 57 of 57
pan.davarias
I have had a surface book for the past year and a half, successfully running Revit, CADDuct and Navisworks.
I Recently upgrades to the surface book with performance base and it works even better.
Very large files can be problematic but that is it
