METRIC CONTENT REVIT 2024
mina_saracoglu
mina_saracoglu
I am new to Revit. Started from Revit 2024. Currently, also getting around Revit Architecture/Structural.
In my installation, I got content English-Imperial by running (update) "US English Content for Revit 2024 " from listings within Autodesk Desktop App.
I didn't find the metric content .I don't see similar option for get METRIC content installed. Can anyone please help me?
NURIATIRED
Hi!
Try downloading what you need from here:
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/2BQRb68xV4vUxhiNWfnv7k.html
If my answer helped you, mark it as good! Thank you so much
NuriaTired
mina_saracoglu
Thanks for helping. I downloaded from here but when i'm in revit I can't see the metrci file from load family.
nuria.cansado
Hello @mina_saracoglu ,
In the Revit application menu, if you go to options you can define the path of your multiple libraries.
You should decide where you are going to place the content you have downloaded and then define the route. (Marked in red with a 1)
*The same would happen for family templates. (Marked in purple with a 2)
I attached a photo.
If my answer helped you, mark it as good! Thank you so much.
