Metal roof above bay window cutting into wall
jdmwrxpower
jdmwrxpower
Hi everyone, using Revit 2023.
  • Trying to create a metal roof above this bay window which I did with a sweep. (I tried to do a roof by footprint but could not get it to work)
  • From inside the model, it's visible on the other side of the wall. How can I correct it?
Thank you in advance
Cut away the portion of solid geometry that is extending through the wall into the interior of the house using an In-Place Void.
