Merge multiple shared parameter files
Sahay_R
Mentor Mentor
Message 1 of 36
Sahay_R
I know that this has been asked multiple times - but maybe someone has come up with something new? I have inherited multiple Shared Parameter TXT files - how can I bring them together  into one?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (35)
Message 21 of 36
I thought that one SP file was the recommended and streamlined way to go?
I don't understand the point of this whole exercise. Yes: one company SP text file is the way to go - ideally.  But, this didn't mean you "retrofit" existing elements. Shared Parameters created from different SP Text Files still report in Project Schedules.  Out of curiosity, what happens when you "include Linked elements" created from different SP Text Files?
Message 22 of 36
Sahay_R
The Linked Elements would be from other disciplines / consultants. Their SP files are on their own.......
Rina Sahay
Message 23 of 36
@Sahay_R wrote:
And how did you take it out of Excel to TXT? When I take your file out of Excel to TXT, it goes kablooie again.....
Save As and choose Text (Tab Delimited) format.  When you close the file, Excel will ask to Save again, just ignore it.
Message 24 of 36
It was a rhetorical question.
Have a good day.
Cheers.
Message 25 of 36
Sahay_R
That's exactly what I have been doing.....except that when I do the SaveAs, Excel shows me the TXT filename on the top bar, and does not ask me to save the file again.
Rina Sahay
Message 26 of 36
The two cells below have extra spaces in them.
Message 27 of 36
Sahay_R
Wow. Talk about Revit being a spoiled diva. Worked finally! Thank you, @ToanDN !
Rina Sahay
Message 28 of 36
In the database universe, a blank in the wrong place can be vital, just like playing Russian Roulette.
Message 29 of 36
Rina, did you figure out how to export excel to .TXT to get it work with Revit?
Message 30 of 36
Thomas_LECUPPRE_Let_it_BIM
Pay attention to the encoding of the file, use VS Code to save it with the correct encoding if needed.
Message 31 of 36
julian_prifti_db
hello everybody, i tried to merge two lists and it worked just by using a text editor and excel, but i have a very funny problem, the spetial german letters like "ü", "ö" etc. are aperaring as spetial characters. I would imagine that could be a issue of character coding like ascii or utf-8. Do you have any idea or approach how to solve this problem. thanks in advance Julian
Message 32 of 36
ReneBogersREBO
Hi there,
I am at a company now, where own parameters are added to a standard-parameter file.
I want to split that file, so the standard-parameter file keeps on his own and the other parameters are in a company SP-file.
Can I just copy and past the lines with parameters to a new file (GUID needs to be the same I know!).
Can I adjust the group-numbers to the needed (new-group) numbers?
One other thing. There are a lot of parameters, that need to be contained, but the names need to be changed, for uniformity.
Is this wise to do? Or better make new parameters for this -> with the result that a lot of things have to be adjusted in the template-file for example.
Hope I made myself clear 😉
Message 33 of 36
arq_42
Although it's not recommended at all , you can make these changes directly in the txt file.
Copy the existing file a couple of times (to keep a backup) and delete the lines you don't want to keep in each one.
You can modify groups aswell.
Regarding the third question, you can change the parameter names, keeping the GUID, BUT!!! Existing families and projects will keep the old name (although since it's the same GUID, they'll still talk to each other).
This can lead to situations like a new project with a parameter called ST_Height and a family in which that same parameter is called ST_hEIGHT.
The only way to fix this (that I've found so far) is to edit the family, delete the parameter with pyArchitect ("Delete Shared Parameter" tool), reinsert it, and reload the family into the project.
So, as said, you have to evaluate whether it is worth all the work, keeping the parameters as they are, or starting from scratch.
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
Message 34 of 36
ReneBogersREBO
Hi Arc,
This is exactly what I thought! 😉
But I was not totally sure, that's why I asked.
Thank you for your quick reply.
I go into discussion here at the company
pyArchtect is new to me. Thank you
Message 35 of 36
arq_42
pyArchitect is an extension to pyRevit, an open source plugin with a lot of useful tools based on python. Take a look 😉
Message 36 of 36
ReneBogersREBO
I thought so, cause of the "py".
I use pyRevit to make custom toolbars/buttons for my Dynamo-scripts.
Still need to dive into everthing in pyRevit, but time is an issue! haha
