Materials
Materials
Materials
1) I am using board & batten material however it is showing horizontal instead of vertical in renderings. I have tried rotating the material 90 degrees however it still renders incorrectly.
2) Also with the same board & batten material - I am unable to change the color (paint or stain). Even when selecting a different color and applying the changes, it still renders in the original color.
See below:
RevitRx
How are you rendering? via Revit? Autodesk Cloud? Enscape? Vray? Twinmotion? Lumion?
www.RevitRx.com
@Anonymous wrote:
...Also with the same board & batten material - I am unable to change the color (paint or stain). Even when selecting a different color and applying the changes, it still renders in the original color.
Add a Tint color
