Materials
Materials
anthonywPWC
Message 1 of 8
Materials
anthonywPWC
None of my material colors or textures will show up.  What do I do??  This image is set on the consistent colors, and I do not know why two roofs are the correct color and the other is not when they are all set at the same material.Revit Materials.PNG
Replies (7)
Message 2 of 8
Are they under the same Phase?
Message 3 of 8
anthonywPWC
Yes, and its only in my 3D view.  If I go to realistic, everything is black, but if I go to an elevation, it shows the correct color.
Message 4 of 8
constantin.stroescu
Have a look on Phases....they could be different ....if you use Phase Filter: None you'll be able then to see all in the same way....
Constantin Stroescu
Message 5 of 8
anthonywPWC
Thank you, I did not realize that would cause an issue.  This might be something that should be addressed with the software.
Message 6 of 8
So it is because of Phase. But in the response to my question, you said otherwise?
Message 7 of 8
anthonywPWC
The Phases were set the same, but the Phase filter was set to show all.  I changed the filter to none and it brought the colors back.  I do not understand why that makes a difference.
Message 8 of 8
I don't think so. The grey walls must be under Existing Phase and the colored roofs must be under New Construction Phase. Highlight one of the elements and look at its Properties.
